Sea Era questions
ronp
Vic, I would appreciate it if you could answer a few questions about the Sea Era. I am considering replacing my Jabsco sometime between now and next season. I would be ordering the pressurized freshwater model.
1. The Raritan web site shows an optional 2 button switch that lets you separately control the macerator and fresh water solenoid when you want to. But I don't see a part number anywhere for it, and so far I have not found it on Boatfix. I want one of those because I believe it would help if I got a clog at some point. Can you supply a part number for that?
2. Does the 90 degree discharge fitting swivel or does it just point toward the rear as it is shown in the parts diagram? It might help me if I could point it down because my discharge hose goes straight down into the floor, but otherwise not.
Ron, when ordering the toilet, add two digits "03" to the model number for the toilet, for example, model # 160MF912 would have the conventional push button switch that is supplied with all SeaEra units. To add the optional two-button wall panel, you'd order model # 160MF91203. It will be shipped with the optional switch included with it. The part number for that optional switch (by itself) is # SWF100. It'll be a "special order" from BoatFix, but it will only add an additional day before it can be shipped.
The 90 degree elbow discharge fitting can be loosened and swiveled to whatever positon is necessary, then re-tightened.
