2001 EFI 5.7L Crusader
Changed Cap and Rotor and now engine will not idle below 2000rpms. Finished complete tuneup, new plugs and wires. Checked fuel pumps and filters.
Had a few folks look at it and they feel timing is advanced. Will only start with plenty of throttle then dies under 2000rpms. Checked wire order several times! Tried old cap and rotor, etc.
Crusader owner's manual says timing cannot be set. There is a wire harness plug for the timing labled "engine timing" and it has a LED that is illuminated. Did not use a scanner but there are no codes per LED other than "12" which means all is good.
Under distributor cap looks weathered. rust and salt. Checked and double checked for loose wires. Only thing I found suspicous was on top of distributor, under cap is a module (I assume electronic ignition) and there was a little oil under it.
Any clues? How does timing work on ECM?
