St Croix Davits on a Carver 3007 / 3207 ?
cruisepilot
Has anyone ever installed, or does anyone have St Croix Davits #300, on their Carver 3007, or Carver 3207 ? I would appreciate any tips on the installation, and what additional support brackets were used externally & internally.
I put St. Croix Davits #400/401 on my 325, but that won't be a lot of help. The only observance I can provide is that the boat squats a bit under power, and the overhang is quite close to the kicked up water, such that the dingy is only just above the water while under way. So when you install the davits, make sure there is plenty of height for the dinghy to stay above the water. It might take more height than you realize.
