For the last 18 months I have had intermitant problems with my H-N-T/ PuraSan set up. I finally resolved it but I wanted to pass this on in case anyone ever has this problem. About 18 months ago it appears something solid got flushed and I never was told about it. Here is the set up ME freshwater head, dumps directly into a newer Poly 36 gallon holding tank. Out of the tank is a Y valve one side goes to the deck pumpout the other went to a Macerator pump that is controlled by a Raritan Hold-N-Treat into a PuraSan. The PuraSan went into a vented loop to a under the hull throughhull. When not in an NDZ the PuraSan would build pressure and not allow the proper transfer of effluent and the tablet dispenser wouldn't always adjust to the fill line it would often overfill. I must have replaced 3 of the junk Jabsco macerator pumps. My plumbing is all 1" on the PuraSan. Finally I thought it might be back pressure from the below the water through hull even though it worked well the 1st year and a half. I installed a new throughhull just above the waterline on the side of the boat. Guess what someone flushed a soda bottle cap it got caught in the outlet adapter inside the 1" discharge sanitation hose between the outlet and the vented loop. It would intemitently flip from closed to half open. Sometimes when I opened the mixer cap I would get sprayed with effluent (yuk) then I would have to do major clean up work inside the vanity under the sink where the PuraSan is located. I only found this after replacing the pump with a high quality SeaLand diaphram pump and the duckbills kept turning themselves inside out with the same backpresure problem in fact it was worse with the SeaLand diaphram pump. Needless to say I hope this never happens to anyone else and if your PuraSan has major back pressure check for obstructions on the discharge side of the unit especially if your discharge sanitation hoses are 1"!
Man am I happy to have upgraded everything but it was very frustrating finding the culprit.
