The California areas that CNN shows as potential drought areas are known to be semi-arid climates. In the case of Southern Califronia, these areas are classified as semi-arid warm steppe climates that are subject to periodic droughts and floods. The climate of San Diego for instance, is closer to the climate of the Mojave Desert than the Mediterranean climate of the Napa Valley. Interestingly, the California Delta and much of the Sacramento Valley are steppe climates, too.
Essentially, droughts and floods are normal. No need to say the sky is falling or put all of our rivers behind dams. The rain cycle will come back eventually.
If climate change is in effect, this will amplify the problem.
Good news: Today, the CA Coastal Commission approved the first water desalination plant for San Diego.
That is why when the pumps are turned on, the current in the south Delta reverses direction. This is not just a rumor, I have witnessed this happening!
