TILT,,,,,, 2 problems ,,, need some advise please
dugcarr1
tilt is a 12V non-hydrolic make. The boat engine model is a 250a /sp volvo penta (aka 151aq)
tilt was working fine, then after 1 month in my driveway it was not raiseing all the way and sounded laboured when raising only. checked battery (was fine), all cables and connections checked and fine. leg was 25% up, and when I tryed to lower it to remove it, tilt stoped working, the motor that powers the tilt was not getting any juice. now i can't remove the tilt to service it.
i can here the click in the electrical box on top of the tilt when i try to operate it. also the 40amp fuse on my engine block is fine as well. i ran a jumper directly to the tilt motor to test it / lower the leg.. the leg lowered finally and now i can't get the tilt unit to even budge (to remove). so the tilt is stuck, and the motor is out and working fine. so it sounds like i have a problem in the tilt motor box (relays?) and the tilt itself? ( since i bought boat boat 1 year ago raising the the tilt alway sounded chuncky and grindy when raiseing).
please give me some expert advice, the manual doesn't help me with these problems ,,, ty for your time.
