TNT hydraulic Lift service needed
ebsuddarth
HELP!! I have an older model TNT lift on my 1995 Sea Ray 450 Sundancer. I am having problems with it. I think I have a leak on starboard ram. I am desperate to fine someone in Southern California that works on these. The factory is in Florida and is not much help out here. Can anyone help me?
Butch
have you called TNT to see if they have a dealer network on the west coast? if not, any larger boat yard should be able to handle hydraulic work and get the ram(s) out for repair/rebuild. very likely the boat has to be hauled to safely work on the lift.
What does it don't do?
Put your photos of the unit on Photo-bucket and post a link here.
I went to Photo Bucket, in the first photo, suddenly a Pop-up appeared. I couldn't get rid of it.
Why do I have McAfee if this sort of thing happens frequently?
The uprights are part of a Hydraulic system that lifts the Skiff off the stern to the water, and then goes down to retrieve it!
Near you is a Machine shop (at least one) who services the Oil Field. They do Hydraulics.
I had the similar problem, you should find a local hydraulic shop who does work with trucks or tractors hydraulics. Some of them can just make parts in the shop. I needed a hose from TNT cost me $170 for 30 inch hose. Found someone near by that made me 6 of them for the same price.
