well, its that time of year again. This board is a lot quieter than I expected....
Anyway, so I live about 10 miles north of Danbury CT. My boat has been out of commission since the end of 07 due to the impending arrival of my wonderful daughter, and the ensuing 2 tears of figuring out how to "do" parenting
We finally decided that this spring it was time. We've missed the water terribly, and we're ready to get back on and in it. As luck would have it, our name came up on our town's waiting list for a slip in the middle of March! That lit the match under my a**; I got he boat registered and insured immediately and wrote the check for the slip.
Now, I'm ready, I need to get her running to see what I have to get done to get her out there. I know for certain that I want to do the impeller. When I put her up I did the outdrive lube... guess I'll have to do that again. I also did the plugs and oil. My fear is the gas. I topped it up, as that was the start of the Ethanol headaches, so I've got 40 gallons of gas sitting there. I stabil'd it at the end of the season, and I think one more time late in '08.
My question is... should I go ahead and put her on muffs to see where we're at? Weather data says (summarized):
*Each winter, on average, your risk of frost is from September 30 through May 9.
*Almost certainly, however, you will receive frost from October 16 through April 20.
*You are almost guaranteed that you will not get frost from May 29 through September 13.
(taken from http://davesgarden.com/guides/freeze-frost-dates/index.php?q=06812&submit=Go)
So is it too big of a risk still? I don't want to have to redrain and antifreeze her once I get started.
Thanks, and happy season!
