Tool to remove VP inner propeller
ddurand
I have a 2011 VP duoprop outdrive. I need to pull the propellers to drain the gear oil. I know there is a tool needed to remove the inner propeller. Is there only 1 tool for all VP duoprops? What tool do I need?
Volvo Outdrive manual covering the Volvo DP-SM, DP-SMTD & DP-SMTD1 outdrives lists a "Front prop remover & installer". Has a Volvo part number of 3855876-3.
VOLVO-3888918 - Soak with penetrating oil first. No torch or you will ruin the prop seals.
You could verify by looking it up by the outdrives. Mine was a Volvo DP and that was the tool.
