Transmission oil replacement for 420 DA
BVasily
New member
any recommendations on type of transmission oil for my 420 DA /w 6CTA engines.
You need to check the manual Some take 30 weight straight and some use transmission fluid.
Moderator
The engine does not matter. You need to post what type of transmissions you have. If you have the manual, it will tell you what fluid you need. My ZF's use straight 30 weight motor oil.
Even knowing the transmission won't help I also have ZF's and use 30 weight but there are other that have ZF's and use tranny fluid. Check the book! If you use 30 weight make sure it is straight 30 non detergent oil.
