Petersen_1955
- Aug 24, 2005
- 18837
- 1
Some background-
I bought a 1975 Cobalt 18' tri-hull, 233 Mercruiser(I/O), this past September. Everything appeared to be in great shape on the surface. I purchased it from a couple that had owned it all but the first year (they bought it from a friend). I paid $3,800 for it and the EZ Loader roller trailer.
I am storing the boat at an indoor storage facility (they also do service work). I had it winterized and yesterday they took off the lower unit to install a new water pump for me. The guy called me up because he found something else that needed attention. Nothing major.
Then he tells me that the transom is pretty much shot and gives me an rough estimate of $2,500-3,000 to repair it. Also the bell housing is cracked in two places by the throttle cable(i think). He said that at some point water must have gotten in there and frozen over the winter to crack it open. No big deal, $75 labor and some JB Weld would do the job.
I went to check out the transom. He took a hammer and tapped around for me. It sounded pretty hollow in most places. The two teak steps on back are pretty loose (no one went skiing since I bought it or they would have pulled out when stepped on). Then he showed me that who ever pulled off the outdrive, put the transom gasket back on and put silicone sealant all around the outside. They also put silicone on the anode bolts. Who ever did this must have known there was a water problem.
Well, I'm not spending $2,500-3,000 to repair her. I guess my question is, who should be responsible for remedying this? What is your feeling on what should be done.
1. If the mechanic didn't tell the previous owner about the problem, shouldn't they repair it now?
2. If the previous owner DID know about it, shouldn't they either fix it now or buy back the boat?
3. Chaulk it up to getting taken(sucker/first-time boat owner), hope that my mechanic will take the boat from me for the work he's already done.
Thanks for your advise.
Pete Petersen
Pete Petersen
