Generally, we take our last cruise of the season after all pumpout stations in the area are closed. So, we've made a tradition of going offshore one last time - usually to Block I - and pumping out whatever might be left in the holding tank during the trip.
This year, to my surprise, the macerator was 'anemic' to the point of being incapable of pumping out the 1.5 or so gallons that were left in the tank.
The pump sounds fine when it starts, but then quickly winds down - to a complete stop within about 10-15 seconds.
If I wait a min and try again it repeats the same scenario.
After hauling for the season, I removed the waste tank (which is built into the bottom of the toilet and connected to both the macerator and pump out connection) and tried the pump again with the waste hose open at the toilet end.
Same result. Runs fast, slow, slower, stop. I hear gurgling in the waste hose when the pump is on, so I don't think I have any blockage.
Sometimes, when the pumps slows down a squeak emits from the pump head. This pump is only 2 seasons old and has probably only been used 6 or 7 times. It has a run-dry feature, but when this occured, there was enough liquid in the holding tank so it shouldn't have run dry.
It's a real project to pull the hose connections apart because the hose fits so damn tight to the fittings. I'd like to trouble shoot the problem without disconnecting any more fittings than I have to. I actually found it easter to cut the hose from the waste tank than to disconnect it from the fitting. Will heating the hose help loosen it?
Anyway, just curious if there is something else I should try before pulling the pump, which is a real project due to it's inconvenient location and the tight hose connections.
