When I got to my boat yesterday my vacuum pump was running. The toilet was empty. It's not the first time. Sometimes the ball doesn't seal completely so I pressed the pedal to open it. The pedal pressed but the ball did not move. When I let go of the pedal, the ball turned so it was open when the pedal was up. When I stepped on the pedal, the ball closed. So basically, the ball rotated on the shaft and was now mis-aligned. So i jest stuck my hand is and turned it to the right position. I cleaned and lubricated the seal and it's ok now. I'm not sure why it froze in the first place.
I know the end of the shaft that goes into the pedal is square so that wouldn't slip but is it ok if the shaft turned inside the ball? Is it meant to be just held by friction? It was tight when I turned it but I was able to rotate it.
