vacuflush bowl sediment buildup
Coolboat2000
We have a buildup of some hard substance on the bowl surface. I tried non-scratch sink pads, but some still remains. What else can we use to remove?
"CLR" (Calicum Lime Rust) Cleaner or Lime Away
I'm not sure CLR is good for the seals in the vacuflush system. Itr might be, but I would be skeptical.
I use regular table salt and a bowl brush. The salt acts as an abrasive and gets that stuff off, plus salt is not a problem for rubber components down the line from the bowl.
Thanks for your responses- but after going to the Sealand website, we found their "bowl & Seal cleaner". We're going to give that a try-
JW
