My vacuflush head got out of sync. Normally when the foot lever is in the middle neutral position the ball is closed.
I stepped on mine and it felt kind of funny and then the ball would open when I released the pedal instead of closing. Obviously the head won't work like that. Lucky it was only liquids.
I took apart the pedal and water valve and got to the spring cartridge. There is a square post on the shaft that turns the ball and a square hole in the spring cartridge. Somehow the shaft was in the wrong position in the cartridge, turned 90 degrees from normal. I realigned everything and reassembled it. Everything worked fine for about two weeks. Then it happened again.
So I'm going to get a new spring cartridge before I repair it. Did I do something wrong? Is this a normal wear item? I've seen a lot about duckbills and clogs but never this problem.
