I installed new duckbills friday. Not a bad project. I did remove and check the pick up pipe. If it was clogged from the start the shop vac clean out took care of it! It was clear. FYI make sure the clamp is at the edge of the fitting to get a good seal!
Test fired the system friday. It held vac just fine. No leaks, Ill check the fittings again soon! I will need more time to USE the head to determine if all the problems are solved!
Thanks to everyone for their help with this dirty job!!
