I have a 1987 Sea Ray 300 Sedan Bridge. The Vacuflush pump is not working. I hooked the power wire directly to the battery and it works. It runs continously while hooked to the battery and does not shut off. (but it does flush the toilet)
The wire going to the pump does not have any power to it. What turns the pump on? Is there a switch that I should check? The wire to the pump goes into a large wire harness and I could not trace it.
