VHF antenna tester
BillyK
Before I go and spend the amount of money it would cost to just buy a Shakespeare antenna, does anyone local have a SWR meter. I have three antenna's and two radios, I want to remove the antennas that don't work and/or hook up the strongest ones.
Billy K.
Walter had one. I used it once. He is away for the weekend.
Let me see what I can do.
No issue. It's in spot we discussed. Could not locate jumper cable. He has one but was not on boat with it. It has 2 males on meter
Walter, thanks again. I may need a couple of days before I can use it. If you had plans for it let me know and I will drop it back off and pick it up when I'm ready. The D/C electric is undergoing a major upgrade and the old fixes are coming back to haunt me. I should be done with it after the weekend.
Billy K.
I'm finished with the tester. Are you guys by the boats this weekend, or I'll just drop it off.
Billy K.
If I am not there Billy, just leave it in the sink in the cockpit. Should be around Saturday, need to change fuel filters.
Walter, missed you this morning. Thanks for the loan. Have a great trip.
Billy K.
Anytime Billy, thanks for the cable, had one just could not find it. All working with your radio?
