So I’m seeing an intermittent problem. Twin 7.4 mpi mercs. Engines run fine. Volts usually between 13-14. But every so often the voltage spikes to 15-16 and stays for a minute or two, then drops back. Happens on both engines at the same time. Gages have been verified with digital data via fox marine gateways. I’m thinking loose ground somewhere and will check that tomorrow or during the week. Any other thoughts or possibilities? Is it even an issue? Thanks in advance.
