The boat is an hour drive away so I can't check right now, but one of these days I'm going to stick a marina water hose into that step drain and see where the water comes out. After the drain line runs through that little wooden box on the wall in the aft cabin (yes, starboard side) and then down toward the bilge, I lose track of it after that -- it's hard to squeeze myself aft of the engines to trace that line. I'm pretty sure it does not run out a through hull. I've always assumed that's the source of the water under the galley bilge hatch. I'm pretty sure it's not the boat (hull, shafts, etc.) that's leaking because in the summer I'll trigger the bilge pump by hand and take the water level down until the pump sucks air. If it doesn't rain, that'll be the same water level when I come back a week later. If it does rain, then the water level is higher,just touching the bottom of the bilge pump switch. The fact that I still have water under that forward hatch when the boat is high and dry on jack stands now makes me think my theory is correct, unless it's leaking through the rails or windows or something else like that. I'll have to nail it down for sure this summer.
