- Oct 23, 2013
- 33487
- 248
I have a Formula 40PC. My water pump was cycling a few seconds every minute. Now it almost does not shut off. Of course I
think I have a leak in the system? I cannot find any water in a bilge or anywhere. I started disconnecting water pipes from the
main manifold right after the pump. When I capped the pipes runnig aft. the pump shut off. The only things aft are my transom
shower, a small sink and hot water heater. I have not seen any water in the bilge area. Could it be possible that the hot water heater coil
(the coil that heats the water from the engine) leaks? When it leaks it goes out the exhaust? I'm going to try and bypass the water heater
to see if that is the issue. If I can reach it? Your thoughts?
