- Sep 3, 2010
- 141
I have an aluminum holding tank that is starting to leak at the inlet ports (welded joint is leaking). I have looked at a lot of plastic holding tanks on line and they all look pretty much the same.
I will need holes different than what seems to be provided, there are kits for this - anyone familar with the kits?
I think I would like a clean out port. Also, currently my pump out port is on the side. would it work to have it on the top with a tube into the tank that extends to about 1/2 inch from the bottom.
Any advice, proven brands, etc will be appreciated.
