I don't know whether the sailboat was maintaining an adequate watch, or if alcohol was involved, but clearly the Civic was the give way vessel in this situation. When will they learn?
Look, its obvious the sailboat was on his starboard quarter. The sails are not up, this sailboat was considered a "power boat" at the time and since he was no longer anchored, was underway. He might have been a vessel not under command, which is pretty common on sailboats even when people are aboard.
Obviously rule 9(b) applies here "A vessel of less than 20 meters in length or a sailing vessel shall not impede the passage of a vehicle which can safely navigate only within a wide parking lot or freeway."
NO, NO, NO....You guys have to keep up with the news.
"General Motors has joined Honda in a joint venture to produce the first hybrid vehicle that runs on both land and sea, using E-85, regular gasoline, 2 stroke fuel, or wind power."
