Winterized last weekend and none to soon. Two day effort starting Sat morning. Weak starboard battery and with 28degree weather and 2mph winds, couldn't start engine(diesel). Replaced battery and fired right up. Had 3/4 full fresh water tank that had to be drained. 6 month old Shurhold 5 gpm variable speed fresh water pump stopped working at 1/4 full. Down to West Marine to buy what I thought was a exact replacement. NOT. In/Out diameter of connectors were different, couldn't use existing setup. Had spare "shark" connectors and temporary jury rigged connectors to at least get pink to all systems. Still had spray at pump connectors spraying in all directions into bilge but got it done. Had ice forming in aft head toilet, had to put space heater in head to help thaw so pink would flow to toilet. Same for aft sink. Had to use blow dryer to thaw spray down faucet at bow to get pink to flow. Open hot water drain into 5 gallon Home Depot pail and went about other stuff and forgot about it for 1/2hour. Figured I had overflowed pail and 11 gallons into bilge. Checked but nothing in pail. Checked pail, crack in bottom, all 16 gallons of hot water contents in bilge. Back home to get wet vac, vac'd all 16 or more gallons from bilge. Nice and clean! Changed oil, filters and fuel filters and zincs in both engines and gen. Pink in engines, gen and A/C system, done by 4PM Sunday. 2 vodkas and water by 430PM.
