Winterizing a Sundancer 260
jak47
Anyone have a check off sheet for winterizing a Sea Ray Sundancer 260? Sanitation, AC, waterlines, etc......
I always did the following when I had mine:
Change Oil & Gear Lube
Empty Holding Tank and Water Tank
Bypass Hot Water Heater
Put a couple gallons of pink stuff in the water tank
Run through all water lines till pure pink, including the head
Disconnect hose to A/C Sea Cock and run 1 gallon of antifreeze through A/C System
I also put 2 cycle oil in fuel filter to fog and put fuel stabilizer in the fuel.
Run Antifreeze through engine after engine is up to temp with - 100 stuff.
Stack cushions sideways and open compartments to breath.
Poor Antifreeze in shower sump and head.
Make sure all batteries have plenty of water in them.
I advice to purchase ShipShape TV's DVD on the subject. I got mine from bigmouthboatsupply.com and the DVD walks you through the steps. Incidentally, they have a 2006 SeaRay for example application.
Oh Darkman, I suggest you delete that link or it'll be done for you. We are sponsored by BoatFix here, and it is quite impolite to list a competitor here (besides, you agreed to that when you signed up here)
I dont view that as being impolite - the video uses the thread authors boat, what are the chances?!
where can i go to buy these voat fix DVD's? I am a brand new boater and I bought a 1986 Sea Ray 30ft weekender. I will need to de-winterize it and have NO CLUE what Im doing. I would like to do it myself. Also any links to any good checklist would be much appreciated!
