100 Ton License question
Capt. Art
When figuring the license tonnage qualifications for the 100 Ton Masters here is the question... (CFR attached)
I see that 50% of the experience is needed in order to use the 150% of the tonnage requirements. But, if your experience is on a variety of owned boats ranging 30 plus tons to 52 tons do they use an average of all the boats or the largest of the boats, to then times it by 150%. This is a critical answer since if your average is lets say 30 tons times 150% then you qualify for 45 tons or you'd get a 50 ton Masters Lic. But if your average is 34 tons then 150% would be 51 Tons but the key here is they must round up to the next level that is in this case 100 Tons? Very tricky but the exact regulation is below. Anyone with a sure answer to this?
I know I'm getting the 50 Ton Masters Near Coastal but I not sure if I'm getting the 100 Ton? It appeared the examiner was not sure either?
[Code of Federal Regulations]
[Title 46, Volume 1]
[Revised as of October 1, 2002]
From the U.S. Government Printing Office via GPO Access
[CITE: 46 CFR 10.422]
[Page 147]
TITLE 46--SHIPPING
CHAPTER I--COAST GUARD, DEPARTMENT OF TRANSPORTATION
PART 10--LICENSING OF MARITIME PERSONNEL--Table of Contents
Subpart D--Professional Requirements for Deck Officers' Licenses
Sec. 10.422 Tonnage limitations and qualifying requirements for licenses as master or mate of vessels of not more than 200 gross tons.
(a) Except as noted in paragraph (e), all licenses issued for master
or mate of vessels of not more than 200 gross tons are issued in 50
gross ton increments based on the applicant's qualifying experience. The
license is limited to the maximum tonnage on which at least 25 percent
of the required experience was obtained, or 150 percent of the maximum
tonnage on which at least 50 percent of the service was obtained,
whichever is higher. Limitations are in multiples of 50 gross tons using
the next higher figure when an intermediate tonnage is calculated. (b) The tonnage limitation on these licenses may be raised upon
completion of:
(1) At least 45 days of additional service on deck on a vessel of a
higher tonnage for a tonnage increase on a mate's license; or,
(2) At least 90 days of additional service on deck on a vessel of a
higher tonnage for a tonnage increase on a master's license; or,
(3) Additional service, which, when combined with all previously
accumulated service, will qualify the applicant for a higher tonnage
license under the basic formula; or,
(4) Six months additional service in the deck department on vessels
within the highest tonnage increment on the license. In this case, the
tonnage limitation may be raised one increment.
(c) When the service is obtained on vessels upon which licensed
personnel are not required, the OCMI must be satisfied that the nature
of this qualifying service (i.e., size of vessel, route, equipment,
etc.) is a reasonable equivalent to the duties performed on vessels
which are required to engage licensed individuals.
(d) Service gained in the engineroom on vessels of not more than 200
gross tons may be creditable for up to 25 percent of the deck service
requirements for mate.
(e) When the qualifying service is obtained upon vessels of five
gross tons or less, the license will be limited to vessels of not more
than 25 gross tons.
[CGD 81-059, 52 FR 38623, Oct. 16, 1987, as amended by CGD 81-059, 54 FR
139, Jan. 4, 1989]
According to the rule as I read it, You can use either (a) "The
of the required experience was obtained" or (b) "150 percent of the maximum
whichever is higher". In other words, you do not use an average of all the vessels you have experience on, but you take the highest tonnage vessel of either 25% of your experience or 50% of your experience and then apply the rule.
I may be wrong, but thats how I read it.
Adam
The Examiner is the one who determines what tonnage you may sit for "for sure". They either don't have your package or it wasn't an examiner you spoke to. Front desk staff, perhaps. Once you submit your package, the Examiner will review it and approve you to sit for the appropriate examinations for the appropriate license. Make sure all of your sea service DAYS qualify and are well documented - it's not as easy as some of the license print shops (or prep schools, as I believe they call themselves, where thwy guarantee passing their test) would have you believe - try that now you'll most likely get caught, and that's not a door anyone wants to open.
November Charlie, in both of your examples it was not correct. They have the package & it was clearly an examiner. This is not for any testing as I completed all of that. The TONNAGE application rule is a loittle confusing as I had different size boats. He was sending it up to a higher review due to this very question I'm asking. I didn't want to just say ok to 50 Tons as I feel I have meet all of the qualifications for the 100Ton.Not to be redundant but I've already gualified in full 100% for the 50 Ton Masters, Near Coastal. Period. If you can reread my question...
AE, let me explain again, in order to get to the point of 50% of your experience lets say you gained that experience on 2 boats. One boat was 30 tons and one boat was 50 tons. 50% of your Sea Time was on these 2 boats. The question is 150% of what tonnage? Am I clear or still confusing?
Mike,
Shouldn't Art be able to determine this before the examiner gets the package? If Art had at least 50% of his sea time on a one vessel, then the 150% rule applies for the tonnage of that vessel. If all his sea time is divided evenly among all the vessels he served on, then he would take the highest tonnage of one that accounts for at least 25% of his time and just use that tonnage.
Adam
Sorry AF not AE. Getting warmer but you have the right idea. Now, I don't have any one boat that takes a full 25% of my experience. So do I add up 2 o3 3 to cover my 50% experience and divide to get an average tonnage or can I take the largest? Why this isn't explained in the rules I can't understand? I can't be alone with this circumstance?
I had approx 800 days Sea Time documented with 6 boats ranging from 5 Tons to 43 Tons (with the 43 ton boat calculated to actually be 52 tons if refigured correctly) boat was documented with the wrong tonnage by broker. It did get a little confusing. *The actual Sea Time Required was only 720 days half of that could be inland the rest was required At Sea - for the Near Coastal Classification. The inland Masters was only 360 total needed.
I'm confused. Did you apply for 50 or 100? And how did you manage to test without a specific ticket approved to test for? Did the approval letter signed by the Examiner that authorized you to test say 50 or 100?
I submitted the completed testing certificates & test scores etc from the Mariners School along with the 100 ton application. The school is fully accredited by USCG for these exams.
If I'm not mistaken, the test is the same. I did the Master Upgrade last year and the tonnage of the license issued to you is based on the vessels that you had sea time on. The other captains in my course who took the same test will likely be getting different grades of licenses. When the app was submitted to USCG, it just stated that I was applying for a "Master Upgrade". I believe I'm finished jumping through hoops and will be getting the 50 ton Master Near Coastal.
I had to specify exactly what license I was qualified to get then doocument why.
In reviewing the paperwork it was agreed 50 ton no problem but THE EXAMINER felt I needed either additional time or more tonnage for the 100 ton. I disagreed then we reread the regs & he saw my point. He said he would send it up to review by superior? I feel I fully qualified for the 100 ton. If I'm wrong ok but why am I wrong? Either way, no problem with the 50 Ton Classification. Next year I'll upgrade to the 100 ton but I should get it now. It's not like I need it for work.
Art,
Since the paperwork has already been submitted to the CG for review, I guess you'll have to wait until you get your license back to see what tonnage was granted. I'm guessing that since most of your time was below 50 tons, then thats what you'll get. I have a 50 ton license now and I'm running a 37 ton commercial vessel part time in NY harbor. I should reach my 180 days by august and I'll upgrade to a 100 ton license. My company also runs four 63 ton vessels which are all new and much nicer to operate, so I'm anxious to upgrade.
Good luck and keep us posted. If you have any questions about work in NY harbor, contact me on the LICC board.
Adam
It must be very enjoyable to run a boat on a daily basis. Thanks
I'll update when I get some paperwork back.
I have received the USGC answer to my question about this 50% rule...
here it is.
720 days of experience are required for the 100 Ton Near Coastal License.
In order to use this 50% requirement of experience they will only count boats in excess of 34 Tons.
That means if you're on a boat like my last boat a 47-ft 2000 Carver Voyager Pilothouse that was documented at 34 Tons it will not be counted or counted as 0 Zero.
Therefore, I can only count my 60-ft that I'd need a minimum of 360 days at sea (50%) to then use the 50% rule. I don't have 360 days on my current boat At Sea.
I still don't agree to this way of calculating 50% of my Sea Time aboard a few boats that I owned 2 of them have been rated at 34 Tons besides the current boat. But, this is the end of my complaint. I will settle for the 50 Ton Masters and just use this season to add the time needed to upgrade to the 100 Ton by next season. I'd like to mention that they Coast Guard has really been very helpful in trying to find out the information I requested. It's just - it is what it is.
End of the story.
Here's a question, is that 34 gross or net tons for your Carver?
It's Gross Tons not Net Tons
Well, as I recall, it used to be the cargo carrying capacity tonnage that was used to calculate the size license you qualify for. Not the gross tonnage. Has that changed?
