10hp Yamaha
JZ
I had my new (15-20 hours?) 10hp 4-stroke engine serviced. They replaced the thermostat as well.
I had it out recently. Water is pretty cold, but even after it warms up it does little more than spit water out.
I can't remember exactly, but it seemed like a steady stream in the summer w/the old thermostat.
Normal or problem?
Clean out the pee hole with a piece of wire they tend to clog if this doesn't work maybe you have a bad impeller.
If you suspect a clogged indicator outlet or hose , a piece of string trimmer mono might be a safer reamer. If you poke a hole in the hose with wire, the water will flow inside the cowling, and if it knocks just enough grease or gomph off the engine to block the small lower cowling drain holes the cowling fill up to the air intake and drowns/siezes the engine . Any time you ream it , it is a good idea to confirm the hose is still attached firmly to the fittings & not knocked loose in there.
OK I guess I should make this a little more clear. I don't suggest ramming a rigid piece of wire in the hole. I like the idea of trimmer mono however if the 10hp is like my 8hp there is no way it will fit. I always keep a small piece of insulated either 22 or maybe 24 gauge wire tied to the motor mount. Whenever the output seems low I just poke the tip of the wire into the hole it tends to clog right there don't go pushing several inches into the hole and don't force it either. If this doesn't work the you can open the cowling disconnect to hose make sure you have pressure if so push the wire through from the inside.
Keep in mind if you are not getting flow from the hose then you may be doing damage running you motor and you need to either replace the impeller or bring to a shop to have it serviced. The clog usually fixes my troubles. I have an older two stroke model and I have been very happy with it I have had it since 1990.
The thermostat should not influence the telltale peeing. Something is blocked.
Agreed however I happen to know the output hole is very small in order to create a strong noticeable stream due to this is is very easy to block. The fact that the thermostat was recently changed leads me to believe that something was simply scraped off like a piece of the gasket or maybe some scaling on the walls and flowed down stream. I believe this will be a quick easy fix!
Often you can find a piece of fishing leader in your tackle box that's the right size for clearing the pee hole.
Thx guys. I'll give it a shot this weekend.
Why not take it back to the Service guy and ask him the questions?
He may see something he missed etc.
Why'd he change the T-Stat at such a low time? The Evinrude Johnson T-stats stay in the block for years upon years.
I've also had new T-stat's stick when the Flap (valve) was too tightly fitted. I just 'distorted' the Valve a bit till it did'nt stick, but still impeded the water flow when closed.
Pee hole was clogged. Small wire did the trick.
