12 VDC Air Conditioner
rmmpe
I've recently seen a few ads describing a 12 volt Air Conditioner that pulls 18 Amps while operating. The picture shows provision for ducting and it apparently does not require water circulation. From that I deduce it must be an air-to-air heat exchanger like the home window units.
Does anyone have experience with, or know anything about, a unit such as this?
Fascinating, maybe. Look also at http://www.swampy.net/iceuse.html There is never something for nothing and the high amperage required will suck the life out of most any battery in a New York minute. There are 36 & 48 volt AC units used on golf carts that work fairly well but are loud enough to sound like a thunderstorm inside the cart and greatly reduce the range.
Should be an interesting thread.
Mike, Palm Coast, FL
According to the 2nd post, 3500BTU isn't much to cool a boat interior. It will suck the battery dry in no time and probably cut off when the battery voltage hits 10.5 or so.
Gary Washienko SAMS AMS
Sound Marine Survey
I had used a Glacierbay 5000btu unit in my 25 Cuddy. It actually worked great however you needed at least 2 dedicated 8D batteries to make 8 hours of operation. Didn't leave much left for the small frig a reading light, the anchor light and radio. I would use it for 3 to 4 hours on hot nights and then I could run all the other DC loads and last the night. The new units by Marine Air are nothing more than a small 3500btu Alternating current unit with a matching inverter. There are always additional losses when converting from DC to AC with an inverter. The Glacierbay unit was purely a DC unit. If you use a DC air conditioner or an inverter to run a small AC unit make sure you have a spare starting battery.
Sidebar to the topic...
It takes a specific amount of energy to chill a specific quantity of air. Period. Some AC units are quieter, some more efficient, some more reliable, but the basic energy requirement does not do away ( though it can get worse! ).
The biggest "catch" to AC is that this base quantity of energy is large. It varies by outside temp and humidity ( and other things ) so it is always difficult for an outside observer to make rational comments to questions such as, "Can I run my AC all night on an inverter and one automotive starting battery?"
The very best, generic answer is that when you need AC the most, you will also need the greatest base energy to produce the desired result. And storing, then delivering that energy is difficult on a small boat. So much so, that doing it with batteries may not be effective about ( WAG ) 50% of the time.
So how do you do it?
1) Plug the boat into that huge multi megawatt coal fired generator 100 sm down the road. Works great. Quiet. You can't leave the dock. No onboard fuel usage. Cheap to install. Should work for all environmental conditions.
2) Generator aboard. Works well. Not so quiet up to pretty D^## noisy. You can leave the dock, but you will need to supply about 0.5 to 1.0 GPH to run it. And a marine genny costs about $1/w. Required maintenance. Should work for all environmental conditions.
3) Battery, using a 12v system or 110v system w/ inverter ( only a few % difference in total usage ). While working, works well. As quiet as choice (1) above. Consumes no onboard fuel. Weighs a LOT. Requires frequent, maintenance. Pricey to install, but less than choice (2). The added weight will likely reduce your cruising mileage. And strictly limited to the amount of energy stored/lead (ballast) batteries carried, thus in the most demanding of conditions will require very large battery banks, or will provide reduced performance.
My conclusion: If you really do not need an AC, but would like to have one, a battery only system should work well. If you work/play where an AC is a need vs a wish, then you need a genny.
Note that displacement type vessels can carry a large battery bank much more easily than a planing type.
Ok. Back to the regularly scheduled topic... [:0]
Folks - it applies to economics, and it applies to engineering . . . "there is no such thing as a free lunch." (translation - energy in = energy out.) A/C systems use ALOT of energy.
All the above is understood.
However, the unit I was referring to appeared to have an air-to-air heat exchanger (much like a typical home window air conditioner), not water-to-air as noted in these specifications. The hot air from the AC unit would be routed to outside of the area being cooled.
Also, the claimed Amp draw was 18.
Am I dreaming here?
I think you are dreaming. The amp draw may be "average with a 50% duty cycle"; I noticed that in a few ads.
Bill and Gene are right. It takes a certain amount of power to cool a certain amount of air; so for the same volume of air, a low-power AC will run more than a high-power one. The end result (power wise) would be more or less the same, any differences would be in efficiency.
You can do it but the # of batteries required will shock you, and you still gotta charge 'em. IMO you'll do better with a couple big fans mounted in your hatches.
FWIW: 5000 BTU of energy can also be expressed as 1.465355kw. The 200 watts you state ( 12V x 18A )is equivalent to 682 BTU. From this subtract the fan and friction energy...
I didn't follow-up on the ad when I first saw it because it sounded too good to be true. Looks like it is.
My interest isn't because it is 12 VDC. It is because it looked like it didn't require water and could be ducted. I'd rather install a unit in a cabinet and duct it than I would to install it on the hardtop or create yet another hull penetration.
A Coleman or Dometic RV rooftop type wouldn't allow that and a window unit is just plain ugly.
I only asked about it because I am not aware of any Air-to-air unit that runs on 115 VAC and is set up for ducting.
Thanks for all the feedback.
Home Depot has them; go to their site. I've seen one on a boat, too, and the folks loved it.
It's possible to convert a window unit to water-cooling, too, and mount it anywhere.
a "ductable" air-to-air unit is an intersting quest, Bob. You realize, of course, that an air-to-air unit is far less efficient than a water cooled unit, and thus needs a bigger condenser (the part that transfers heat to the outside air) compaired to a water cooled unit; that's why those 'hatch mounted units' are so big. As space is an inherent issue on most boats, water cooled units provide significantly more cooling for thier size, and usually fit under a bench seat. It's usually pretty easy to duct from there.
Also, to gain any kind of effiency on an air-to-air A/C unit, you'd have to put the condenser outside the cabin (like a hatch mounted unit); otherwise, part of your cooling is used to cool the heat you just removed!
Good luck - if you find a unit with any kind of 'significant capacity' (say 5,000+ btu's), please post - I for one would be curious to see it.
The "portables" come in sizes up to 16000 btu. the btu/amp seems to compare with ordinary window units, and they run on 110. They're fairly large though, certainly won't fit under a seat. $500+
Google "Amcor AC"
(I think I'll go down to the boat and take some measurements)
I had a 10,000 btu (home) air to air for my cuddy and like GoodGrief said, they aren't that efficient. Currently I'm finishing the install of a Krusin Kool (price was right) into a permanent mount a/c for the cuddy. This is a 7,500 btu model.
I used a 13,500 RV roof air conditioner on the flying bridge of a 42 foot motor yacht with success. I currently use a Coleman Polar Cub 8300 BTU RF roof top air conditioner on a 27 foot pilot house catmarran. I run a Honda EU 2000i for the power supply. I have run a 5000 BTU marine AC unit off 6 golf cart batteries and a 2500 watt inverter-but I would only get 4 to 6 hours (but enough to cool the boat down). We use a "endless Breeze" 3 speed fan on the foreward hatch at night--or a Walmat 8 D cell/12 volt fan (as low as $12) for ventillation when not running the airconditioner (we don't run the AC when we are asleep--the Generator is on the swim step--and there are CO moniters etc.
As I thought.
I had a rooftop AC unit on another boat and had to remove it because it's weight aggravated stability.
I also don't like installing a home window unit on a boat because it looks a bit silly seeing that big exchanger growing out of a bulkhead.
Guess it was a "pipe-dream".
Thanks for all the comments.
IF you can find a private AC repairman to do the work it's not that difficult to convert a window unit to water-cooled, but you still have to figure out where to install it and how you're going to power it.
