12 volt battery selector
rtribble
My 12 volt battery selector switch allows for battery 1, battery 2, all, and off.
When I leave the boat I've been in the habit of turning the switch to the off position as the bilge pumps are direct wired to the batteries. I have allways assumed that my shore powered battery charger would keep the batteries top't off but now that I think about it, terrible thing thinking about it, I'm wondering if the charger goes through this switch or is direct wiredalso?
Just finnished winterizing our boat last week and got to thinking "what if's" since I won't be personaly checking on the boat as often through the winter if the batteries were to run down because the bilge pumps were runing due to a leak and the charger wasn't keeping them charged.
God I hate winter coming with too much time to think/worry about things.
Anyway anyone know if the shore powered battery chargers are normaly wire direct to the batteries?
On my boat, the battery charging wires from the three phase stage AC powered charger go directly to the positive battery terminals, not through the battery switched cables. That's the usual method. The automatic bilge pumps are wired directly to the battery as well and the main battery selector switch is left in OFF position while the boat is at the slip.
The battery charger on my current and previous boat were connected directly to the batteries..
yzer, 3 phase bat charger? Where are you supplying it from, and you got 3 phase in a 26' cris?
If you want to be absolutly sure it is wired right, simple test. You either need a meter or a 12vdc test light. Unhok your bats. With switch off, and bat charger off, no shore power conections, hook meter to battery conectors. Meter or test light should show 0vdc or no light. Turn charger on, you should read around 13.6vdc or light should light. If so, you are right, if not, need a bit of work done to redo the bat charger conections......D............
Rtribble: You need to find out, and correct it if need be. You can do the test as D suggests or trace the wires, whatever works for you. But find out.
Some boats are hooked up one way, some another. You don't know till you check.
Assume NOTHING on a boat; it could be VERY expensive.
Thanks Stmbtwle, of course you and D.Andrews are correct, even though my boat was factory wired the only real way to know would be the test. Since my boat is a couple hundred miles from home it will be a little while before I can verify the charging issue but have had the boat several years so a few weeks "shouln't" make a difference. Just never thought of it till now.
Thanks All
yep, put a meter on it, turn it on and off with the bat switch off and you'll know right away. Charger output shoudl always go to the batteries but you never know what a previous owner might have done.
D. I think yzer meant 3 stage... not 3 phase AC...
On a lot of boats the charger outputs go through fuses or circuit breakers on the way to the batteries. If they are tripped you won't charge no matter what the position of the battery switch.
I keep the 3-phase power supply in a big box on a small barge in the next slip (heh,heh).
No... I used the wrong word and meant "3-stage charger."
Can't get much by anyone on this board.
