12 volt television
rjr
Apparently my old tv is about to turn black unless I can find a 12 volt converter box. Seems like a good excuse to upgrade to HD. Anyone have some advice?
I apologize for this post since it must be here somewhere. I couldn't find the subject.
OUr Toshiba 14" LCD with built in DVD player came with a 120VAC to 12VDC transformer. WE cut off the transformer and wired it to DC ..... works great.
Sharp Aquos' are also 12 volt running off converters from 120 volts.
I don't think you'll find a 12VDC converter box. You can run a standard 120VAC converter box off an inverter ( 12VDC to 120VAC ) ....using any one of your 12V batteries.
Or just upgrade to a new LCD/HD TV...and run that off an inverter.
Good Luck........
Jensen 12VDC TVs are great they are HD ready and the circuit boards are conformal coated so they can operate in a damp environment. I use them in my boat.
Sunkey SK-801ATSC is a converter which works on 12 volts DC. Artec makes at least 3 different 12 volt converter units which have good reviews.
You can run almost any small TV off an inverter. I have several 12 to 16" LCD's which run off 12 volts (clip the wall wart and put on a 12 volt plug)--but these are not necessarilly HD. I recently purchased a Westinghouse 16" at Sam's for $168--runs off an inverter. I also got a 7" HD TV which works on batteries, 12 volts or 110 V at Radio shack--sort of the "personal TV" Also there are several converters for lap top computers which give HD TV off the air, and are equal to the dedicated televisions for about less than $100.
So you have lots of options.
I have a Sharp, they are 12 volts. You can buy the pulg that fits the power port {cigarette lighter)for them. I suggest getting an inverter you will use it for many more things as charging cell phones,ipods,use DVD players, satellite recievers,etc.
I picked up a Polaroid 19" this past summer from Target. I kept looking at the TVs in Circuit City and Best Buys. The salesman must have thought I was nuts since all I kept doing was turning the TVs around and looking for an exterior transformer that was stepping down from 110V to 12V. This TV turned out better than I thought. It has a built in DVD player, a built in SD player to show pics and the picture is outstanding. I just did as others and cut the plug off and wired it to the power feed from our old TV.
We used the Artec converter for most of the summer of '08 and it certainly is a good solution for the digital switch. Wish I would have purchased two with the coupons.
How about a USB HD digital tuner for your laptop? They can be had for about $49.
We use a Toshiba 15" LCD TV/DVD on the boat. It was built to operate on either 110 VAC or on 12 VDC with a standard 12V plug.
We also have the Artec T3A converter for the boat TV. It comes from the factory as a 110 VAC device, but I can run it on the boat with 12 VDC with this. Plug this into the Artec instead of the 110V AC wall wart. It's just the usual boat supply stuff plus a small plug from Radio Shack.
Great install. Yeah, I can get 27 channels with the converter but half of the new channels are Spanish language (no comprende) plus some children's and religious channels. There are about ten new channels I actually use.
After the February deadline the number of digital channels is expected to triple in our area.
I wouldn't count on that. ALL of the stations are broadcasting in digital right now. They've been required to broadcast both analog and digital for some time now. The February deadline is the CEASING of analog transmissions only.
Thanks.
Well the US Congress is considering postponing the conversion for several months because the government has run out of money to subsidize converters. I checked the US Constitution and Bill of Rights and I cannot find where either guarantees citizens free or subsidized TV access.
Personally, I’m tired of hearing about it and it's my belief that anyone who hasn't figured this out by now and made arrangements for the conversion is just too stupid to get any benefit from television.
Perhaps if they can no longer watch TV they will get up off their butts and get a job to occupy their time. [:-mean]
Ron, I could not agree with you more. Let's just do it and get it over with, for crying out loud! I can't believe they're actually talking about postponing this AGAIN...
Supposedly, money for the digital TV converter coupon program came from the broadcast and electronics industries. I don't think much of it came from the government to begin with.
That's not the way I understand the situation. After the deadline frequency space that is currently used for analog channels will be used for digital signals only. Most of the digital channels are now on UHF, including digital channels from the VHF stations. So there will be additional digital stations available on both VHF and UHF after the deadline.
