1999 Larson 254 Cabio
Moderator
Anyone own one, I have a friend that has one and he has some questions.
There is a deck plate under the steps to the cabin, is that access to the forward bilge? It is filled with water???
I'm assuming you're talking about this hatch?
If so, this hatch if the forward bilge access. There is a bilge pump and also a shower sump. When I did the new flooring this spring, I pulled up some of the subfloor in order to reinforce it. Further up towards the front of the bow there is/was what appears to be hoses from the shower. I'm assuming that at one time the front bilge would take the shower water and then be pumped overboard via the bilge pump. It looks like it was disconnected at some point and reaplced with a true shower sump box.
Does that help?
The deck plate covers the forward bilge area. The bilge area should be dry. Possible sources of the water might be:
Leaking water tank
Leak in the water system
Leaking shower sump
Leaking water pic-up for the air-conditioner
Leaking hull
Water intrusion from portholes
Bottom line is the water could be coming from many sources but it should not be there. There should be a sump pump in the bilge, but it must not be working. If it was working he would have at most the small amount of water the bilge pump could not pick up.
He should immediately get rid of all the water, then fix the bilge pump. Then he can start working to find the source of the water.
DL2525 nice flooring. I should have known this was a custom job. When I first said it I said my my Larson has certainly stepped up their game with the teak flooring but it is just DL2525 who stepped up his game. I like Larson the Delta Conic hull is a winner with me and the boat is put together pretty well. Some of the shifters suck but Larson does not make those.
Thanks Jason! I love the flooring.
You can read more about the interior here - http://www.boatered.com/forum/topic.asp?TOPIC_ID=138194
