2 foot - itis..... beam wise
johnnyk
Observing boats in the used market and have come across several that are 9/10 foot beam. Two that come to mind are a Rampage 24' with an inboard ( out of my price range) and several 26' Imperials with I/O drive.(singles and twins)
Are there any other 24 thru 26 foot boats that have a wide beam and a flat cockpit area? The Imperial is all open/ flat behind the helm seat. No engine hatch to get in the way of fishing.
Looking to lessen rocking and rolling on Lake Erie....
Shamrock 24 Grand Slam
Northcoast 24
Black Watch 26
Blackfin 24
Blackfin 25
Blackfin 27
Pursuit 27 CSS (very rare boat and hard to find)
Tides 27
To name a few
Edit: The Blackfin 24 and 25 have 8' beams. Are you trying to lessen the rock and roll at drift, or under power?
Any cat will dampen it. As will a sea anchor.
Boy do I need glasses, I quickley clicked on this because I thought it said "two foot Tits"
Good point about underway or drifting. If drifting, you might want to look for a boat with less deadrise.
Or look for one with variable deadrise for the dual benefit of good ride and less rocking when drifting.
Originally posted by Grand Larsony
Searay Amberjack 26' with 10' + beam
You'll have to go back a while for one of these. Last one that close was the 1985 Amberjack SRV 255 with a beam of 118" and a deadrise of 22 degrees. The larger AJ with a 10" beam was produced until 1990. The current 270 version was reintroduced in 2005 after a hiatus of several years, and has a 8.5 foot beam. Wish it was wider, though.
The 2006 250 AJ also had a 8.5" beam, and was really a reconfigured 245 Weekender.
