2 stroke oil recomendations
estame6
I understand that your always going to get some oil odor from an OB but I would like to minimize it. I made the mistake of using some weed wacker 2 stroke oil and read that OB's don't reach the temps to effectively burn off the oil. Our local auto store sells multi-purpose 2 stroke oil that mentions it's suitable for any 2 stoke engine. I'm hoping someone can point me to a product that is specially designed for small OB's and doesn't produce the gag effect I seem to be getting. BTW I have a small inflatable with a 1995 15hp Johnson that has never seen ethanol and runs well. Thanks for any pointers.
Have you ever decarbed? evinrude used to recommend decarbing every 50hrs with the 2 strokes. I have found that the 2 strokes smoke a hell of alot less after a decarb. Evinrude/Bombardier sells a product called Engine Tuner. Merc calls it Power tune and yamaha calls it Ring free. Sea Foam works just as well or better.
As for the oil try the OEM brand.
I had great results with Valvoline semi-synthetic TC-3 in my Johnson 175. Much less smoke than with pure 'fossil' TC-3. I found an online retailer that sold it by the case (6 gallons) at a really good price. That was in 2007-2008, so don't know for sure anymore.
You should not be using any old 2-stroke oil. It's gonna cause carbon buildup, soot and smoke. Once the unburned oil 'cokes' on the cylinder walls, you could break a piston ring. Use the oil type recommended by your manufacturer.
My .02
TC-3 is a must! I've also heard about what Zane said. Never did it but I do remember reading alot about it. As a future OB owner, I'll be following this.
Even though I have a big block four cycle,I love the smell of a two stroke motor. To me it smells like SUMMER. <g>
You need a marine oil. I have a 2000 Johnson 150 and I would recommend either Penzoil XLF or Evinrude/Johnson XD50. These are synthetic blends with detergents that you can get at Walmart or most sporting goods stores. Also a +1 to using Seafoam regularly.
I always run the engine manufacture's blend. If I can’t find that I buy another brand i.e, merc/Yamaha etc. If I can’t find that… then I will settle for tcw-3. Oil is cheap compared to a power head replacement. Mfgrs put a lot of effort into creating a quality product that works with their design. If you have a warranty, especially a manufacturer’s warranty, then I would use their brand only. I won’t name the brand, but we called it “red death”, aftermarket engine oil. I just don’t risk it. IMO
Thanks to all,
TC-W3 from Wally world fixed my smoking problem. As mentioned I have a mid-90's 15hp and using today's tc-w3 oils I'm not worried who makes it so long as it's tc-w3 rated. Newer equipment I agree with mr-know-it-all often the newer stuff needs certain additives to keep them running top notch and in warranty and all this can be found out by chatting with manufactures representative (dealer) and joining the manufactures forums and listening to the know-it-all's ................... HA! love it, keep up the good work, it's good to read lots of opinions, I think it's great that people take the time to share their knowledge and experiences. IMHO
