20 min repair
dvan
How many times have you said that a 20 min repair turned into a 2 hr job? Sat. I finally pulled the boat into the shop to replace the lower unit on my outdrive. It wouldn't go into gear easily, so I thought the clutches were going bad. I had another lower end so I finally decided to replace it. I took the cover off the box were the cables connect and I noticed that the cables were loose going down to the outdrive. After further diagnosis I noticed that the pawls that hold the tension were not engaged, I corrected it, and yee ha it worked fine.
With all the time I had left over I fixed the wiring to the port tilt switch that has giving me problems for a long time, and replaced all my dash switches with rocker switches. Well all but two, I didn't remember that the wiper and the nav. light switches were three position switches, so now I have got to still replaced those two. Still took me about 6 hrs of work , but I got a lot done.
I will probably have to practice docking with both motors again, I have been only using one for a quit awhile.
Hey Dvan,
Since you have so much time left over, I am having a little trouble with my running lights and radio.....what time should I be at your place.
DBH
That work would take me a couple of weekends. I'm on Delta time.
Glad to hear about your success Dennis! It's a great feeling of accomplishment when more is completed then planned!!!! You must be an expert at single engine docking by now.......
DBH, bring her on over about 11 am Sat. Oh wait that is when I will be on the water. Oh well......
