Proud new owner of a 2004 420 DA. Several items need fixing up and I am hoping to get some advice from DA owners.
1. Water pump very loud, vibrates and periodically will not shut off. HAve checked for any signs of water leaks in system and there appears to be none. Is the repairable or am I better to purchase a replacement ... or other?
2. Master Stateroom head appears to lose its seal. I suspect this is simply a Vac-u-Flush maintenance kit.
3. Top side fridge vibrates, is loud, and seems to run +70% of the time. Any advice short of replacement?
4. Generator not pumping water now. Suspect an impeller which I will check.
Appreciate any advice from seasoned owners.
