2008 Boating Accident Statistics
Lots of eye opening information in there! Thanks loads!!
Thanks, Flutterby. There is a lot of info here.
I have always had a problem with these reports. This is sort of a non-specific problem. It looks to me like they are asking the wrong questions, or they are asking the right questions in the wrong way.This makes an analysis of the data difficult.
Just as an off-the-cuff example: A 17 yr old with a few beers in him is involved in an accident with injury while operating his vessel at high speed in a well-traveled area. If you look at the data collected, this incident might be classified in several different ways. ( For the purposes of this example this operator is by definition inexperienced ).
It may be classified under any ( or all ) of the following:
Inexperienced
Alcohol related
reckless operation
inattention
violation of RoR
youthful operator
Also note that one category is "Rules violation", but that there are also categories for BUI, failure to maintain watch ( inattention ), reckless operation, excessive speed, all of which are RoR violations...
So, while the report(s) DO bring forward areas that can produce problems, the data is collected in such a way that it is difficult to derive a practical solution.
( At least one exception: It would appear that accidents in cold water months have a higher fatality rate, likely due to hypothermia )
So, again, while the data is welcome, and it certainly is better than no data, there are better ways to handle this information which would allow all involved to better increase safety ( regardless of the method of the solution ).
But from the data, I can conclude that: ( no particular order )
Mother Nature can be a Muther.
Operation and "recreational substances" do not mix well.
Speed can be hazardous.
Cold water can be really dangerous.
Check out the chart for "time of accident" Mid to late afternoon, which isn't suprising to me, lots of folks getting liquored up in the sun. The lack of life jacket use is appalling! We don't wear them cruising out to anchorage, but my rule is: if you're in the water, you have a PFD.
Statistics can have little practical value if not interpreted correctly. For example, in examining the 2008 stats, it is recorded that zero persons died from carbon monoxide poisoning while wearing their PFD, but eleven died of that cause not wearing a PFD. Can one then build a case that you are much less likely to die from carbon monoxide poisoning if you faithfully wear your PFD? The raw statistics support such a conclusion, don't they?
Safe and Happy Boating!
ColonyCove
ColonyCove
Hehehehe....yea...kinda...but the first thing I assumed when I read your post, was that more carbon monoxide poisoning happened when at anchor or docked...not underway, where and when most people wear their PFDs which is probably why that statistic is the way it is.
Colony Cove, I read the report and I only found 3 deaths from carbon monoxide poisoning? I think you are looking at related accidents, not necessarily deaths? I didn't read the whole thing, but I was curious about CO deaths. It appears there were 3 deaths and 9 injuries. I wish they would specify which were from a portable! :-)
Radioactive, as always you bring up some excellent points. Remember, I am just the poster of the link and have nothing to do with what or how it is gathered.
A nicely drafted letter to the USCG may have a better effect........
Raw data is always open to interpretation, for example age groups 35 - 55 have the highest number accidents, does that mean this age group is the most reackless or least experienced or are there simply more operators in this age group and by percentage may have the lowest number of accidents? Flutter's posting should be a wake-up call for the more dangerous times on the water and "worst" boating practices.
Going by the statistics, I should have a 65 foot or larger steel hulled boat with a 10 hp motor that can travel more than 40 mph! Riiiiiiiight!
Stats, esp. ones that come from the Gov. are almost impossible to get information from.
They are tainted.
Look at the cover sheet.
I have a beer can in my boat right now.
If I was involved in an accident, it would be alchol ralated (if they found the can).
The fact that I make everyone that smokes put their buts in that can, has nothing to do with anything, as far as the Gov. sees it.
It would still show up as alchol related, even though it might have been 20 days since that beer was consumed.
Their was a boating accident on the lake where I live two years ago.
The local press went and took a photo of the boat, out of the water, on a trailer, in a recovery yard, through a fence.
It had a beer can on the front!!
Headline was, Alchol involved in boat accident.
Contacted the newspaper, because I could'nt understand how that beer can stayed on that boat, on the bow, after it was pulled from the lake, towed 15+ miles on a trailer.
They said that I needed to go buy the print version, because they found their "mistake" and photo shoped it back out of the print edition.
I wanted to know why they set the photo up, since they were not suppose to be inside the locked security gates to begin with.
Look, the beer can was put into the photo electronically, to support the headline.
Only after people started to question their "ability to report the truth", did the photo's go back to their original stage.
I know in NC, you best stay away from Farm Ponds.
It was skewing their data, so far to the left, that they had to drop the inclusion of the data.
It did not support their agenda.
