as ddurand said, 135 might not be too cold, you need to give more info.
Does the boat have antifreeze & a heat exchanger - with seawater only cooling the exhaust ( aka FWC or closed cooling) , or does it pump seawater through the entire motor ( RWC). If it’s RWC, and you run in saltwater, I believe the merc thermostat should be fully opened by 140 degrees, so would not be surprising to see those temps. looking at the merc parts, i think 8M0089715 is the thermostat for a RWC version of your motor - not sure though if you have a 4.1l/250, or a 4.5l/274. But this is a 140 degree thermostat. Holy cow these new motors are complex, with 499 million parts!
The FWC thermostat runs 20+degrees hotter. the theory being that it’s not good to have 150+ degree saltwater running through the motor.
if you are running an RWC boat in freshwater, I suppose you should use the hotter thermostat?
