27 santigo prop size?
atdg
Hi can someone tell me what is the original prop size that came on 1989 27 santigo twin 3.7L?
thanks for info.
From the Carver Manual...
I can tell you that I have a 2757 Montego and the factory props did not let the engines get to max RPM. I downsized to 15 pitch props and it perfroms beautifully now.
Thanks it's 2767 santigo and i got 15/17 prop's on
it takes to long to get on plain.
atdg - I would first look at all the stuff that affects performance including the cleanliness of the bottom of your boat, how long since a tune up, unnecesary weight on board...
You might also want to take the props somewhere to get them checked for the proper pitch. I got hung up on my old boat because I assumed that the props were the pitch that was stamped on the side. The guy before me had taken them to a shop to have the pitch changed. I was going back and forth between two props that were identical and I couldn't unterstand why the boats characteristics didn't change when I swapped them.
