1995 290 Sundancer with 4.3 LX and alpha one drives. Underpowered or not a problem. Dry weight of 7700 lbs. Has AC and Gen which will add a little extra weight as well. I thinks the LX is listed at 190 hp.
I had a 26' (29 LOA 8.5 beam) with the 4.3LX Alphas, displacing about 7500lbs. I ran about 45MPH with no issue getting out of the hole. I belive the LX are actually 205 hp, but I could be wrong. I think underpowered is not a problem.
The horsepower is determined by what kind of fuel delivery you have. Electric fuel pump with carb or fuel injected? The 4.3 has a hp range from 190-225 depending on the system. A 2bbl= 190, 4bbl= 205, FI= 225.
I have a 240 searay. It's been redone and added to but full tanks and gear it weighed 7660Lb at truck scale. I never believe the weight claims made by the mfg.
Your underpowered. I had a 28' Wellcraft Martinique with twin 4.3 190 HP mercs with alpha drives. Had to run the snot out of it, terrible fuel consumption.
