3227 Air conditioning picts
geomut
I have a 3227 with an non-Carver Air installed in the mid-cabin locker. Need to see some pictures of unit and air duct through locker to vent in main cabin. 17k btu unit but not getting enough air up to vents. Thanks
I will snap pictures for you this week, but mine is not mounted there. It is mounted under the aft portion of the dinette in the Salon.
Mine is mounted under the dinnette seat right next to the sliding glass door. It is in a different location than yours but I had the same problem as you. The vent line had slipped off of the vent cover to the right of the dinnette. I would check your connections and clean your filter if you have not done that.
Mine is under the closet in the lower cabin. When I got the boat it had a wood duct that was covered in carpet that leaked so bad the only cool place was in the closet. I put a piece of flexible duct with transitions to the duct for the v berth and lower cabin, I then put a damper in the large duct at the top to balance the flow. I then insulated it. Big improvement only downside I lost most of the lower cabin closet. I will take pictures if you would like
Ross
It would be tough for me to give up that closet in the midcabin. I have four shelves in there and it is where we store most of our groceries.
Anyone have a chance to locate any picts of the mid-cabin locker A/C and ducting? Thanks.
http://i971.photobucket.com/albums/ae194/willysross/achttp://i971.photobucket.com/albums/ae194/willysross/utf-8BSU1BRzAxNDcuanBn.jpg/IMAG0147.jpghttp://i971.photobucket.com/albums/ae194/willysross/utf-8BSU1BRzAxNTUuanBn.jpg Well that only took 2 hours
OK i give up send me an email and i will send you all the pictures. I have posted pictures before but not off of my phone.
