5200 - how tough?
SHEP
How tough is this stuff really?
I want to mount a 24" by 14" piece of plywood to (smooth) fiberglass then mount an amplifier that weighs 8-10 lbs.
will it hold?
Vertical or horizontal? 5200 won't stick to raw wood all that great, especially if there's any dust on the surface. 5200 doesn't have the ability to readily encompass(as in wet-out) as ,say, epoxy or polyester resin would. It does stick to clean, smooth surfaces tenaciously. Painting the plywood with polyester resin(fiberglass resin) will give it that smooth surface and the polyester resin will wet-out(soak into) the surface of the pkywood.
i stood my plywood up, vertically, using L-brackets into the floor and bulkhead wall (ski boat). carpeted the board to match, ran the wires neatly behind it and out through holes in the board to look real clean, and mounted the amp up high on the board.
you want the amp mounted vertically to dissipate heat better. i'd be concerned with the weight pulling the fiberglass apart over time, keep in mind rough water too.
Not entirely marine related, but 5200 none the less...
My son plays lacrosse and needed a vertical wall to practice on. We took 12" concrete pavers (about1.5 inch thick) and used 5200 to attach them to two pieces of 3/4" plywood screwed back to back. That was over two years ago, and it is still tight and no looeseness or any degradation.
go for it.
dave
5200 is very strong, but its not a true adhesive like epoxy. Its an adhesive/sealant as it says on the package. If you use some epoxy adhesive or some epoxy resin mixed with milled fibers, this will be much stronger than 5200. Make sure both surfaces are scuffed well with sandpaper and brush some epoxy resin (without the milled fibers)on the plywood, then add the milled fibers to the rest of the mix to make it thick like a putty, spread it on the plywood and try and keep some pressure on the plywood as the epoxy cures. It will be bonded forever.
I agree with the epoxy group--especially with the heat, and weight of an amp. Be sure that the fiberglass is rough sanded, and before that cleaned with acetone or dewaxing solvent. Agree with the micro fibers or milled fibers (milled are slightly longer than the milled)--Cabosil (Fumed Silica is often used to thicken the epoxy also.
I believe that in this application that there is some risk of the 5200 giving with time--it it works, it works very well--but as pointed up, it has some minor defeciences as an adhesive.
I've got to add my 2 cents to this topic.
According to 3M the tensile strength of 5200 is 700PSI. Assuming they are correct, it would take 235,200 lbs. of force to pull the 24 X 14" substrates apart. Is it strong enough to hold a 10# amp.? I think so. Plus, it's elongation is 1350%, which means it will stretch by that amount before failure.
When a manufacturer lists a product as an adhesive/sealant they are telling you it has a dual purpose. It can be used as an adhesive if the bondline is thin or it can be used as a sealant if the bondline or bead size is thick.
An epoxy (ANY EPOXY) has good tensile and shear strengths but poor peel and impact properties. What you want for your application is a product like 5200. However, keep in mind the cure rate. It's going to take a very long time for the 5200 to fully cure. It cures by moisture adsorption and it is going to cure from the perimeter inward.
I would add some mechanical fasteners from the reverse side if possible. They will act as a clamping mechanism until the 5200 fully cures.
If you opt to use an epoxy, I would try to find a modified system (flexible epoxy). You'll have a better chance of it taking the abuse it's going to see on a boat.
