5200 repair
CCoon
I recently repaired a portion of a sundeck with 5200 and a section of Seaboard (a plastic plywood similar to starboard). When I went back a week later, the 5200 had dried and pulled away from the caulked edges of the plastic. Does 5200 not adhear to certain plastics? I used it because I had a tube on the boat. If it doesn't work, what would be better.
Basically, nothing adheres to Seaboard/starboard. Though there are very expensive adhesives that require a special applicator that will obtain some kind of a bond 5200 is not one of them. If you had routed a dovetail on the bottom, then the 5200 could mechanically lock into that space.
Al
Starboard has recommended that you use a mechanical attachment. The best method is to use screws/bolts and make the through holes oversize, due to the material's high coefficient of thermal expansion. They state ( or at least, they used to state ) that even though they have specific adhesives ( as stated above ), the performance is not sufficient for most applications.
( From memory of fabrication and technical datasheets provided by Starboard in the past, which I can no longer find... )
I'm not sure that 5200 would be my first thought for repairing something. No, it won't bond to starboard, at least not permanently.
What are you trying to repair? Would a simple fiberglass repair be a better idea?
Seaboard and Starboard are polyethylene and nothing bonds to this plastic. As stated above, there are some specialty adhesives that will give somewhat of a bond, but I wouldn't count on it. What were you trying to repair? There may be a better material that will bond and thus avoid using fasteners.
the rightstuff by permatex does bond to many plastics but it only comes in black
I'm repairing a sundeck. It is a large area of about 3x5 feet. The area is recessed about 2 inches for a cushion, and lended itself nicely to a starboard inlay. I was trying to avoid a big fiberglass repair job, but it looks like I'm going to need to do this. The manufacturer had placed plastic velcro holding plugs through the glass. Water has begun to seep around the plugs and is causing delamination of the glass to the wood underneath.
When I bought my boat two years ago, the previous owner had a mount for a satellite dish bolted on to the bow. The dealer removed it and covered the area with a piece of starboard and glued it down. I don't know what he used but there is no way it's coming off.
If the area of the sundeck is allowing water intrusion into the wooden core, this is a formula for disaster. You need to be sure that there is no rot, and then repair it using fiberglass and polyester resin or fiberglass and epoxy (epoxy will be a stronger repair, but more difficult to adhere gel coat to--or it may need to be painted) However, this is not an application for Starboard.
You may want to double check, I would not be surprised if there are fasteners into the bottom. In this case the "glue" would be acting as a sealant. Either way, eventually there is a good chance that the "glue" (unknown?) even if keyed into the starboard, will eventually stop acting as a sealant. This is for me one case where silicone's are a good choice as you can make them work like a gasket when paired with mechanical fasteners.
Anyhow, you might want to investigate further just exactly how the starboard was affixed if there is opportunity for core leakage.
I think the piece of starboard is just cosmetic. The bolt holes were filled and then they just glued the square of starboard over the four holes to cover it up.
