89 omc rpm
Aaron C
Does anyone know what is a good rpm for a 27 ft with a 351 omc..I have been running at 3400 is this a good speed or should i run it higher(or lower)
If that's a wide open throttle (WOT) figure, then I'd say its low. Been a while since I had a 351 in anything but I'd bet that 4000-4400 would be a closer figure. Do you have a manual? It should tell you. My 26' boat with OMC 260 (350GM) has a WOT range of 4200-4600rpm. To me, it sounds like you're over proped or out of tune or not trimmed properly.
