hey guys, a friend of mine is having a hell of a time with this overheat problem,
the engine temp climbs above 170 rb2@gr5t idle but not much higher, when you take it out & run it, the temp is steady rb2@gr5t 185ish. when you idle down, the temp spikes over 200, closed to 230.
the boat has new impeller, thermostat & manifolds/risers.
any thoughts
the impeller was changed for maintenance, not due to failure, no debri/damage found. the RWP runs off of the belt/pulley set up similar to the bravo set up but smaller,.
the RWP hose runs to the thermostat housing , which was also addressed & nothing found there.. the hoses all look in great condition, the boat has only been used on lake but it does have over 800 hrs on the motor.
any ideas on how to run down a blockage?
also, when first diagnosing the o/h the IR temp gun read 20 degrees hotter on the starboard riser than the port riser. after risers were replaced the same result only a bit cooler
any thoughts
