A follow-up Question
bmetros
Thank you all for the information concerning tilt/trim/tabs. I will apply that information this weekend. I have a follow up question though, what is the difference between the tilt and the trim buttons on my I/O. On my old bass boat(OB)the trim button would tuck the motor in or raise it up.
I think this is the last piece of the puzzle.
Thanks again!
B-the tilt should be to raise the motor for trailering, trim to adjust the motor while running.
You will notice that the trim button will not raise the outdrive very far but the tilt button will raise it all the way.
Never use tilt while under way. It raises the drive higher than the lateral supports and can cause a lot of damage.
