Some models allow you to switch to LARGE digets, showing speed, bearing, etc etc. This is a useful feature. When they put a map on the screen, the data boxes can get pretty small.
Keep in mind, if you're going 23 mph against a 7 mph current, you'll see 16 mph on your gps. This happens all the time in areas like the SF Bay/Delta or the Puget sound. You need to keep this in mind if you're doing time, distance, fuel burn calculations.
