Ablative Bottom Paint Recommendations
Chriznat20
Ok, first off I know there are other bottom paint threads, and I've read through them. Lots of useful info. :)
My question is I've narrowed my decision down to Microns Ablative Paints. But there appears to be 3 or 4 different "levels" of Micron Ablative bottom paints. I boat on a fresh water lake and I have a 25'8" 1999 Four Winns Vista cruiser. I dont mind repainting the bottom every year, I have a trailer and I have access to the boat all winter. Im concerned that the lowest level of Micron ablative might wear off before the boating season is over! is there anybody with recommendations/suggestions on these paints?
I want shark white so my choice of other brands is very limited.
Here are the "levels" of Micron based on price:
Interlux Micron Extra
Interlux Micron CSC
Interlux FG Bottomkote with Irgarol
I've used Interlux Bottomkote on a 26' cruiser in fresh water. In the water all year long. I had it on three or four years and it worked well. Probably all you are going to need for a trailered boat, so long as it holds up to the trailering. Maybe someone has used it on a trailored boat...
I posted earlier today micron csc I got nine years can't remember if it was two or three coats. It stayed clean also. Follow directions on the can and enjoy the results Good luck Jim
Les, I've heard you discouraged sales of liquids because of the shipping costs, but the Boatfix bottom paint prices are SIGNIFICANTLY lower than the nat'l stores. What's the ballpark cost to ship a gallon?
Chriz, I didn't mean to hijack your thread, but I figured that if you can buy higher quality paint at a lower price, it might influence your choice.
I boat in salt water. Do you really need bottom paint on a fresh water lake?
Not all ablative paints are true multi-season paints, and therefore with some the boat can not remain out of water for long periods of time without the paint being "reactivated" or repainted. Several coats of a good multi-season ablative paint applied over an initial "telltale" coat of a different color will indicate when it is time for a recoat. If you look at the directions on the different types of ablative it may say to launch within so many days of application. A good multi-season ablative will not have such a time limit.
Erich
Eriche, DIFFERENT stuff grows on boats in fresh water, but not necessarily LESS stuff. Fresh water boats are especially at risk if they're kept water that's warm and/or still.
..and the boat may be previously bottom painted. The herbicide in any of these paints won't last much past the first season, but you can "freshen" the surface layer by wiping them clean, exposing new copper.
Let me clear some confusion first: I dont trailer the boat- it stays at the marina from April-October but its on a trailer during layup. Sorry if I didnt state that clearly!
And on Lake St Clair a bottom paint is absolutely necessary, especially on the west side of the lake. I know, because I didnt bottom paint last year and now I have a fabulous black bottom even though we scrubbed every weekend. [xx(]
So far the bottomkote is the most economical. But I've heard that its not multi-seasonal - how firm is this label? Is it going to wear off before the season is over? Does anybody else have experience with the Micron BottomKote?
I have used Fiberglass Bottomkote ACT in past, all season no haul and when boat came out bottom was clean. Also had good luck with Petit Horizon last season.
Liquid Diet - thanks for the input! Im pretty much sold on the BottomKote ACT with irgarol.
Shark White isnt very white just so you know
Mike, that's the nicest bottom paint I've ever seen. Usually, it's that aqua-green/blue looking crap, but yours looks very nice. Is that ablative or a barrier? Or do I have no idea what I'm talking about and abaltive is a barrier?
IMO- Go with black. I've used shark white too, you'll see the scum line. Black covers it all. Good idea to go with the Irgarol- will help retard slime.
Chriz,
Our last two boats came off superior and michigan respectively... Interlux Fiberglass Bottomkote has peformed very well, even after moving the boats to our slightly warmer South Dakota lake.
Just a few touch ups here and there, and it powerwashes clean every season. It is also less expensive (If i remember correctly) compared to some others. We've been very happy with it, and are a little apprehensive that our new boat will have the Petit-Hydrocoat on it. Would much rather deal with a bottom paint we've come to know, that has worked well in the past.
OBTW, we used black.
thats a customers boat. it actually hade barrier coat applied before the paint. it is Micron CSC, Shark White. its a copolymer antifouling. basically a "self" polishing paint. like an ablative in terms, but doesnt need to be moved thru the water to replenish it... if you get that
I have had excellent results with Interlux Micron Extra. Two coats will last around four years.
