Ablative or hard bottom paint
Wingspar
My new boat cruises around 16 knots. I'm wondering at what point you should use the hard bottom paint instead of ablative.
I cruise at around 20kts, and use the soft stuff: it works fine, and with one coat per year, it doesn't appear to be building up.
dv.
its not the speed, but whether you keep the boat in our out of the water. most ablative bottom paints must remain wet at all times and have max life out of the water of 24 hours. this detail is often not on the can but buried in the product data sheets. generally speaking hard bottom paints can be stored dry.
What is an ablative bottom paint and what is a hard bottom paint? My bottom paint is in serious need of a recoat. The old owners had her kept in the water, but I keep in on the trailer. Which should I be using when I go for a recoat?
Justgot,
Ablative paint wears away like a bar of soap, hard paint doesn't.
If the bottom was painted with hard paint repaint with hard.
Not good to paint hard over ablative paint.
You want hard paint when you use it on a trailer ablative rubs off too easily when you take on and off trailer.
I'm sorry, but Vic's info is backwards. Ablatives are Multi-Season Paints. They have some biocide qualities but are designed to sloth off growth as the paint wears away while the vessel is underway. Ablatives can be left dry over extended periods. If you rub a rag on a painted bottom and the color comes off on the rag its an ablative. Normally, unpainted bottoms painted with ablatives get 3 initial coats, the first coat being a different color than the final 2 coats. When enough paint has worn away that the first coat color is exposed its time to paint again. Ablatives need only a light sanding before the new coats are added.
Hard paints are just that, hard. They depend solely on biocides to kill off the growth. Hard paints are generally used on boats that remain in the water all year. Most hard bottom paints have a very limited life when the boat is dry. Read the label carefully to determine how long a boat with a hard paint can be out of the water before the biocides begin to lose their effectiveness. Eventually, bottoms painted with a hard paint will need to be sanded and stripped to get rid of the build-up.
I agree and disagree with Mikee on certain points.. Hard is a good choice for trailer boats as it does hold up better when on the trailer. Certain ablatives are single season and will have issues if left out in the air. Good ones are multi-season and can "re-activate" when launched after a layup.
Here's the catch.. Most of the boats that are in the water full time down here are all ablative types.
I think it's the other way around.
I'm having hard paint put on my boat and according to the manufacturer, once the boat is put in the water, it can only be out for a maximum of 72 hours before the paint will no longer repel bottom growth.
I might have gone with an ablative or a "multi season" ablative, but I have a diver clean the boat and this would damage the softer paints.
I use ablative on the hull and hard paint on the keel and running gear. It's worked well. Boat stays in the water.
Dave:
The manufacturer of my boat used ablative paint for the initial exterior from the waterline down. I ran for 7 seasons with ablative, painting over the remaining exterior each spring. At the suggestion of the service manager who looked after my boat during that time, it was sanded right down to the fibreglass and replaced with hard paint, 3 springs ago. That surface has only been powerwashed each spring since then. Always kept in the water over the winter months, and basically inactive during the winters.
You know my boat and you know how I have used it. I'm staying with the hard paint.
p.s. You are wearing me out, just reading about all the work you have done on that boat this spring.
Thanks for all the replies.
Currently my boat does have a hard bottom paint on it. I've had slower boats in the past and like the idea of little or no buildup of ablative paint. It's been my understanding that ablative should not be run on planning hulls do to the higher speeds wearing it away quickly. I'll stick with the hard stuff for now.
There are no issues using ablatives on planing boats, my boat cruises at 22-24 knots and I always use ablative. They are designed to wear down but it doesn't happen that quickly. If you're starting with new paint they recommend 2 coats to build up enough thickness but I just put 1 coat on a year and have been fine.
The major paint manufacturers have paint selection guides on their websites. These would be a good place to determine the best paint for your boat and conditions.
Dave,
If you think 16 knots is running fast and you shouldn't use ablative you're mistaken. 16 knots is slow compared to the boats coming out today with ablatives on the bottoms.
I run at 26-27 knots cruise with ablative and get 3 years out of it.
You can paint ablative paint over hard paint, no problems with that. I would go that route, you don't want that hard paint build up, you will either curse the yard bill to remove it or curse the work that goes into removing it.
I have never had problems with ablative paint on a boat that does not go on a trailer.
Only paint I will use for a non go fast.
Same here, ablative paint (Interlux Micron Extra) on a 17 knot boat that does go on a trailer sometimes. Here's some of the marketing points Interlux uses for Micron Extra:
- Suitable for use on all boats in all waters and can be hauled and re-launch without repainting
- Micron Technology polishes to a smoother surface than hard antifoulings maximizing fuel efficiency
- Controlled polishing like a bar of soap – reduces paint build up and eliminates the need for sanding
It's not the cheapest paint, but considering I get at least 3 years out of it, it's well worth it and probably saves money in the long run.
"No ablative on planeing hulls"?????? I wouldn't put anything but ablative on my boat. With hard paints, you get one season anti-fouling and the paint builds up year after year.
LOL I get a kick out of all the different answers here! Here's my story: I have a planing hull runs at about 27 kts for best fuel economy. I had the boat yard put on an epoxy layer and then 2 coats of Interlux Micron Extra in 1992. After 7 yrs it needed new bottom paint or......I decided to put the boat on a lift instead. 18 yrs later, I still have the same ablative bottom paint; it looks fine; power washes well, but sits out of the water 90% of the time.
Why put on knew bottom paint if it is stored on a trailer? That is cosmetic only and no one sees it when you are using the boat.
My Tiara came with ablative Alwgrip on it from the factory and I renew it about every three years. I do paint the smile every year due to acid washing that causes discoloration. We cruise at 24 knots....no problem with wear.
