Are you going to use the boat this winter? If so, how are you going to heat the interior? As I have said in another post, unless Christmas '98 comes around again, you really do not have anything to worry about.
Worst case scenario, get in a dink and back blow low pressure air through the system until it bubbles out of the raw water intake. Shut the sea cock and your done.
I live just south of Richmond and have friends who spend a lot of time in Hampton during the winter. They have yet to winterize in over 20 years of boating in the area.
HTH
EDIT: I wrote the above making an assumption you are leaving the boat in the water. If not, back flush some fresh water through the system and follow that with low pressure air. If you have bug problems, cover the intake and outlet with duck tape.
