goblehipcom
- Mar 24, 2008
- 29681
- 19
I have a 2001 Regal 2960 with a vacu-flush head and, as far as I can tell, there is not a holding tank vent filter. We do get post-flush smells when the holding tank starts to get full, so I was thinking of adding an Sealand filter. Can anyone see any problems with doing this?
I did find a bit of information:
VENT LINE AND FILTER INSTALLATION
* Holding tank vent lines must be free of low points which can trap liquid and prevent the free flow of gases from or air into the holding tanks.
* Do not use non-reinforced hose for vent lines. Over time, it will tend to kink and effectively block the vent.
* A holding tank vent filter will absorb heavier-than-air gases associated with sewage and eliminate a source of malodor from the exterior of the boat.
When installing vent filters that are not mounted directly on an HTS unit:
* Avoid areas near excessive heat sources such as engine manifolds or lights.
* Do not install the filter below top of holding tank.
* The filter can be mounted in any position. Installations near the through-hull vent reduce the chance of filter damage from overfilling of the holding tank.
The filters look easy enough to obtain (maybe a little pricey) ...I just need to figure out the size of my vent line so I get the correct size filter. Anyway, not sure if there was a reason (other than cost savings) that the boat did not come with one...or, if there are other issues to consider (I've owned the boat for 1 year).
Thanks for any extra info,
-Brian
2001 Regal 2960 Commodore
"Full Circle" - Seattle, WA
Twin 5.0L Mercruisers with Bravo 3 drives
-Brian
